Stainless steel being an expensive material, it's an usual piping engineering practice to use small schedule numbers (i.e., 10, 20) when at all possible. In this case, wall thicknesses are small and the pipe and fittings are subject to deformation and warping, as Stringer and Weldingfool pointed out.
In Weldinccaw's case, however, schedule is 120, which means a good wall thickness. In my opinion, this will make deformation or warpage negligible, or at least acceptable.
Nevertheless, taking into account Stringer and Weldinfool's warning, I suggest Weldinccaw to run a test and see what happens before making the final welds.
