Situation: Large warehouse on the MS gulf coast [i.e. salt water environment] with concrete floor with nominal one-inch wide expansion joints. These joints are to have continuous embedded angles on each side, say L3x3's. Both embedded angles will be 'recessed' below the finish floor, the same thickness as the continuous cover plate. The primary floor traffic is a pnuematic-tired forklift with max axle loads of about 32,000 lbs [or, about 8,000 lbs per tire].
Say the cover plate is 1/4" thick for starters. On one side I want to field-weld via slot welds, say at about 12" c/c, to the embed angle. [Weld only on one side of the joint to permit movement of the cover plate over the opposite embed angle.] Due to the salt environs, all joint steel will be HDG. It's possible it could end up being SS. My concerns:
1a. Is there potential for curling of this plate so that it sticks up [even if slightly] above the finish floor?
1b. If so, should the plate be thicker, or should a different weld 'pattern' be done, or should we abandon welding altogether and go with a screw-fastener type anchorage?
2a. If curling/warping is NOT a problem, either thru 1a or 1b, do you think these welds will hold sufficiently under this forklift traffic?
2b. Do you have any first- or second-hand experience with a similar joint construction in a heavy warehouse?
3. If HDG is the finish, how durable is galvanize touch-up?
4. If SS is to be welded, what does this finish [at the weld area, haz, etc.] look like as compared to the adjacent un-welded areas?
