Up Topic Welding Industry / Welding Fundamentals / live tap
- - By lo-hi (**) Date 01-27-2014 12:49
There was some discussion about live tapping in the shop talk section and thought this might be handy for some body. Its a home made taper. I tested it at a 100 psi on a hydro and no leaks. Its been used on chill water and heat lines but no steam yet.
Attachment: IMG_20140126_164925.jpg - live tap (865k)
Parent - - By 803056 (*****) Date 01-28-2014 00:41
Interesting!
Necessity is the mother of invention.
Parent - - By Superflux (****) Date 01-28-2014 06:59
Excellent work. What did you use for the packing material?
Parent - By lo-hi (**) Date 01-28-2014 13:32
I took the top of the valve off and used a piece of 9/16 drill rod to replace the stem. It retains the original packing and you can just tighten the nut to keep it from leaking. Be sure to remove the packing before brazing or it gets real smokey and leaks. I sure this could be done with a carbon valve and skip the brazing part. The pilot bit on the real ones are bigger on the end and split so they retain the slug.
