I like running both Lincoln and ESAB T-8 electrode wires ! Especially out of position... Way better than T11's in my opinion.
They are designed to run better in the upper WFS range "in my opinion" But the voltage range I've found is best at the lowest value the manufacturer recommends without spatter occuring...
I've also found that a split root pass done with stringers is more effective than a wider root-pass that might have some side to side movement. Split roots take a slightly larger gap/opening sometimes, but if you can accomodate it and not be bothered with a little extra overall weld volume, it may solve your issue without any further fuss.
Edit:
The split root technique is the answer to many problems related to single bevel CJP issues.
Check Contact Tip to Work Extension? Self Shielded FCAW is pretty sensitive here... Worm tracks are the typical result of this being wrong, but maybe cracks too?.......... Still betting on split-root for a fix.
Last thoughts: with 211 and 232 most operators like to run vertical with the gun pointed downhand about 15 degrees...
NR233 the same slight drag, but some operators find that closer to perpendicular works for them a little better... I said this wrong the fist time...The Current vs WFS on 233 is much different than 211, I think due to a thinner strip that is rolled.... But if a reduction of WFS on the root can provide a slightly more narrow stringer while still giving enough punch to fuse to the backing and still comply with your WPS... This might help also.....
http://www.lincolnelectric.com/assets/global/Products/Consumable_Flux-CoredWires-Self-Shielded-Innershield-InnershieldNR-208-H/c32400.pdfLast last.... I've also experienced NR233 to be more sensitive to arc blow and have seen it punch holes clean through base metal in very little time..... You don't mention this, but it has been an issue for me on a number of occations.
