As promised:
New Steel-to-Aluminum Welding Process for Honda
Three developments in joining contribute to lighter door panels, better performing vehicles
Robert Brooks
Wed, 2013-02-20 22:49
"Honda Motor Co. Ltd. will implement a new welding system it has developed in order to join steel to aluminum, so that the light metal can be used to build outer door panels of the 2014 Acura RLX. That new model becomes available in North America in March 2013. The new method will be extended to cover production of other Honda and Acura models in the future.
This new technique follows a Friction Stir Welding method that Honda introduced in 2012 for continuous welding of dissimilar metals (e.g., steel to aluminum) in the production of vehicle subframes.
General Motors Corp. also introduced a steel-to-aluminum joining process in 2012, a resistance spot welding technology it developed involving a patented electrode design. Like the new Honda method, GM’s development will allow it to incorporate aluminum in automotive exterior panels for doors, or hoods, lift gates, etc.
Honda noted that welding steel and aluminum for external panels called for simultaneous advances in different joining technologies, including methods of preventing electrical corrosion that results from the reactions of different materials, and controlling the thermal deformation that results from the different expansion rates of steel and aluminum.
Combining simultaneous developments
Honda said it made three developments that allowed it to achieve industrial-scale production of aluminum outer door panels.
Combining these developments, the automakers said is able to avoid the spot-welding used to form door panels in conventional production, but it is able to do so without replacing its current production lines.
Honda’s first, critical development for joining dissimilar materials is the "3D Lock Seam," a structure in which steel and aluminum panels are layered and “hemmed” to create a double seal. Then, it developed a technology that prevents electrical corrosion by using anticorrosive steel for the inner panel and a new form that ensures the gap between the two panels is filled completely with an adhesive agent.
Next, it introduced an adhesive agent with a low elastic modulus and optimized the location of the 3D Lock Seam, to control thermal deformation of the material during the joining process. The new production process helps to reduce door panel weights by approximately 17%, according to the developer, compared to standard steel door panels, thus contributing to greater fuel economy.
Also, Honda pointed out that reducing weight reduction at the outer side of the vehicle makes it possible to concentrate the point of gravity toward the center of the vehicle, which improves stability in operation."
Edit: This is a follow up article written in February of 2013 to the article above:
http://world.honda.com/news/2013/4130218New-Technology-Join-Steel-Aluminum/Respectfully,
