No need to SHOUT, I'm just curious!
I have looked it up, and found nothing to indicate that this rod needs any more than ordinary care. I also read the small print disclaimer at the bottom of your chart, saying that "...the times and temperatures given are not necessarily correct.", and, that you should contact your rod manufacturer for any critical work.
