Up Topic Welding Industry / General Welding Discussion / shielding gas for stainless mig
- - By saxdoc Date 03-08-2003 19:40
Hi everyone, great forum! I have a lincoln weld pak 100 I bought a mig conversion for it. My question is I want to weld 3/4" diameter stainless steel pipe with it and I am trying to decide what to use for shielding gas.
I know that the best choice for stainless short circuit transfer would be a mix of 90% helium, 7.5% argon,and 2.5% co2, but that mix will be difficult to get in my area, also I want to set this up as economically as possible. Is there another gas I could use with stainless which would also work for mild steel welding? Is it possible to weld stainless using co2, or argon only? what about 75%argon, 25% co2 ( this is readily available to me) Any help would be greatly appreciated.
saxdoc
Parent - - By brande (***) Date 03-09-2003 04:56
The old 75/25 mix will weld stainless. The only problems are that this mix tends to give a "ropey weld" and greatly compromises the corrosion resistant properties as well.Especially on multi-pass.
As far as operation with a easily available gas, Stargon, or argon tri-mix might be a choice. This gas can still compromise the corrosion resisting properties to some extent.
In corrosion critical weldments, my choice has been a 97% argon/3% CO2. CO2 under 4% have little effect on stainless corrosion resistance.
This gas will short arc or spray as needed.
Do stay away from the helium tri-mixes. The high helium content (the 90/8/3 mixes) increases heat (by increased arc voltage)to the weld, regardless if in short arc or spray.The last thing we need on gauge thickness stainless is heat.
While I know that spray arc is not available on a machine of your size, and if your requirements are basically lo-tech-I would go with the Stargon or argon tri-mix. You will find this mix very helpful on thin gauge carbon steel as well.
Good Luck
brande
Parent - By saxdoc Date 03-09-2003 17:40
Hi Brande,
Thanks for your informative response I will probably try the argon, 3% co2, bottle. I think I can get that fairly easily and though this project is not high tech, I do want the welds to be sound, and corrosion resistant, as well as have as good an appearance as I can produce. I also found some great info at the weldreality.com site your advise seems right in line with theirs as far as steering away from the helium mixes cheers,saxdoc
Parent - By ScottV (**) Date 03-10-2003 04:01
Brande,My friend runs a welding store,and was welding some stainless with some tri mix gas,023 wire,using a sp135 plus 120 volt welder.He turned up the wire feed,and voltage,and got that little lincoln to spray arc.It really shocked him it that it was posible to do with a 120 welder.He also told me that 98% argon/2% co2 was good for a tiny little weld bead in short-arc.My friend has welded with about every machine out there,and this was impressive.I can spray-arc with 90/10 with .023 ER70-6 wire with my sp175 plus,and almost with .030 wire but not quite.
Parent - By Michael Sherman (***) Date 03-10-2003 12:11
Sax, have you considered running stainless flux core wire? I use it exclusively for all GMAW applications. It is easy to use, aesthetically appealing and the recommended gas is 75/25.
Mike Sherman
Shermans Welding
