By 803056
Date 05-03-2014 13:25
Edited 05-05-2014 00:56
If the fabricator is welding unlisted materials, the materials used in production must be qualified for each combination and thickness range needed for production. To put it a different way, if welding A to A, a test assembly consisting of two pieces of A and A must be welded. If welding A to B, the a test assembly consisting of both A to B must be welded. And if B is welded to B, then you guessed it, a piece of B must be welded to a piece of B.
The fabricator must have WPSs qualified for the positions needed to accomplish the welding under production conditions. If all the work is positioned in the flat position, then that is all that needs to be qualified.
Determining the positions needed for production can be more complicated than one might think. Figures 4.1 and 4.2 can be used to determine the required test positions based on production requirements. Once the production positions are determined, Table 4.1 is used to determine what production positions the WPS is qualified for one the test coupons are welded in the flat, horizontal, vertical, or overhead positions. Point of fact; the test positions for the PQR are flat and level with respect to Earth, i.e., the figures 4.1 and 4.2 are not tolerances to be applied to the position of the test assembly. In the case of the vertical test position, the groove or the fillet is perpendicular to Earth. As with the flat test position, the tolerances of figures 4.1 or 4.2 have no bearing on the position of the test assembly. Likewise, the tolerances of the figures do not apply to the orientation of the horizontal or overhead test positions.
Table 4.1 will give you all the information you need regarding the production positions qualified by the PQR assembly, but it may take a little study to appreciate all the conditions that apply. Be sure to read the footnotes to see if they apply.
Good luck and ask simple question so my simple mind can wrap itself around it.
When it comes to qualifying the welder, with permission of the Owner (the entity that takes legal possession), the welder can be qualified using a prequalified WPS. The intent of welder qualification is simply to verify the welder can deposit a sound weld. The mechanical properties were verified when he WPS is qualified. Now, if the Owner requires the welder to be qualified to a qualified WPS, that's his prerogative, and he must be satisfied. The Owner is in the driver's seat. As they say, "He who holds the gold makes the rules."
