Up Topic American Welding Society Services / Technical Standards & Publications / minimum requirement for full skip or Half Skip distance- UT
- By magesh (*) Date 05-21-2014 01:39
Hi
   What is the minimum requirement for full skip or Half Skip distance for UT TESTING According to AWS D1.1?
   Please confirm
    Note: Should be justify through code book (If AWS D1.1 Recommend)
    We need to have UT  inspection for the space between the stiffeners is 130mm distance thk-32mm plate. Welding Joint type CP.
   Thanks
