Ted: If I where you, I'd look at the dynisty welder by miller, alot cheaper and (about $5,200, inverter,cooler,cart, and torch) you can dial the arc to a point where you can hardly see the line created by the cleaning action of the arc. Which was what I was looking for, as we are making aluminum railings that are grained and can't be touched up for apperiance. It's an inverter type machine so it is very compact, where as the aero wave is a larger machine giving basicly the same results. 350 syncro is a good machine, but the dynisty, ahhhhh. Check the machine out, have someone give you a demo with it, or try it yourself.
Like any machine, especially a tig machine-you got to live with it a while.
That said, you will really appreciate the newer tig units available today, if you are fussy about your welding.
The old 330 ABP was a very good tig machine on DC. Spit tungsten like a machine gun on AC, however. (Got the x-rays to prove!!)
Because of the 3 position range switch, lo amp work was,at times,challenging.
I made a living with a Syncrowave 250 for the past 15 years. Really liked it. This winter, I bought a Dynasty 300 DX (accountant said I had to spend some money!-boy, did I spend some money!!)
I have found the Dynasty very good down low. I have been playing with the balance and frequency controls to shape the arc on AC-I still have a way to go on this. Running AC on a pointed tungsten gets some getting used to-but it works!!
The pulser on this machine is also great benefit.
I guess what I am trying to say here-all the little tips and tricks you learned on your 330 are no longer needed with the new inverter based tig machines like the Dynasty and Aerowave. They offer a level of control only dreamed about earlier. AC welding is as easy as DC.
Do you need an Aerowave? Can't say. Remember, too that the Aerowave is not really a big machine, amp wise. It is still only a 300 amp machine when run on three phase. It is only slightly bigger than the Dynasty, a 250 amp machine when connected to three phase. This power difference can often be made up by choosing the proper gas mixture of argon/helium.
Seems to me, FWIW, that the Dynasty is more of a manual machine and the Aerowave is more suited to automatic type welding. Just my opinion, though.
Find a good weld supply with a demo room. Run the Dynasty a while-I'm sure you will like!!
Hope this helps
brande
