Up Topic Welding Industry / Technical Discussions / Plasma cutting AWS C4.6M / ISO 9013 / ISO 17652-3
- - By FracingVin Date 05-30-2014 14:28
I am trying to locate someone with knowledge and/or experience performing testing to AWSC4.6M
I am actually testing to ISO 17652-3 :thermal cutting:, which refers to ISO 9013 :classification of thermal cuts:
I see that the ISO 9013 is referenced in the AWS standard.
I do not know if there is a certain shop which tests to these standards?
I am testing a shop primer on A36 to see the effect it has on cutting speed. Primed versus non-primed to obtain a R value (reduction factor)
Any information will be helpful since a current project of mine is relaying on these standards.
Parent - By 46.00 (****) Date 05-30-2014 21:20
I wouldn't put to much into the reference to AWS!
