Up Topic Welding Industry / General Welding Discussion / Cost Calculators
- - By tack271 Date 03-13-2003 16:19
I am looking for a program or site that has mig and stick cost analyzation program to compare the cost difference between the
two applications.
Can anyone help me?
Tks. Mike
Parent - - By jwright650 (*****) Date 03-13-2003 16:36
Try the one pipewelder_1999 has on his web site. See if that is what you are looking for, here is the addy...........
http://www.weldinginspectionsvcs.com
John Wright
Parent - By pipewelder_1999 (****) Date 03-13-2003 19:46
Here is the address for the cost comparison download. http://www.weldinginspectionsvcs.com/welding_cost_comparison_program.htm
Also remember you must supply all of the variables such as filler metal cost, labor cost, dep rate, dep efficiency, production factor. Many of these are available on mfg websites of filler metal.
Thanks for remembering me John
G Austin
Parent - - By M-Squared (**) Date 03-13-2003 22:01
Mike,
I have an Excel Spreadsheet that will compare the cost of any two processes.(SMAW,FCAW,GMAW,SAW, GTAW) Weld joints include, Fillet, single-V, Double-V Single Bevel, Double Bevel, Compound bevel.
It will calculate how much time is required, how much wire, gas , and flux, it will show you how many bottles you need if you are using gas. It will break down how much labor cost, wire cost, and gas cost.
You can even change between English and Metric units. I tried to send it to your e-mail but it would not go through.
Let me know if you are interested.
Parent - By tack271 Date 03-14-2003 11:57
That sounds exactly what I'm looking for.
My personal e-mail is
mikejr@islandoxygen.com
Thanks to all who helped.
Mike
Parent - By pipewelder_1999 (****) Date 03-14-2003 04:37
Also, A spreadsheet that was written by Mark F Mruczek is on my website for download at http://www.weldinginspectionsvcs.com/weldCostExcelDownload.htm
This program is the way to go if you have excel. It has much more detail than the one I referenced above.
Good calculatin
G Austin
