Be safe up their this one down the road from me turned out horrible today.
http://www.kentucky.com/2014/07/02/3320645/man-is-decapitated-while-working.html A man was decapitated Wednesday while working on a Verizon cellphone tower on Waits Road in Harrison County KY.
The man, whose name was not given, was 240 feet in the air when an antenna fell, said Harrison County Sheriff Bruce Hampton. Either the antenna or a broken strap decapitated the man and cut off one of his arms.
Police were called about the incident at 2:20 p.m. Hampton said he spoke to a foreman and was told four men were working to replace the tower's antennas, which each weigh 1,800 pounds. WKYT, the Herald-Leader's reporting partner, reported that two of the men were working atop the tower and two were working on the ground when the accident happened.
One antenna had been removed and was being replaced when it fell just two feet away from the tower, Hampton said. The man was still in his safety harness when he was killed. The Northern Kentucky Technical Rescue Team was called to get the man down about 6:15 p.m. Wednesday.
Hampton said the man's name would be released Thursday after his family was notified.
Read more here:
http://www.kentucky.com/2014/07/02/3320645/man-is-decapitated-while-working.html#storylink=cpy
