Up Topic Welding Industry / General Welding Discussion / indirect butt joint
- - By ed17 (*) Date 06-27-2014 17:32
hello everyone im back for more questions!! i think it's 21 question time!! ha ha!! Anyway we have to qualify for a indirect butt joint with A706 grade 60! my question is 'does the splice plate have to match the grade of the bars? Or can we use say A572 grade 50 or does have to grade 65? thanks so much for the help!! Also i do have the D1.4 Structural Welding Code--Reinforcing Steel and i could not find any mention of this?
Parent - - By 803056 (*****) Date 06-27-2014 18:58
Ultimately, the strength of the splice material and the filler metal has to be as strong as the rebar. Weaker splice material, longer welds and thicker/wider the material. Weaker filler metal, longer welds.
Parent - - By 46.00 (****) Date 06-27-2014 19:24
Al-your supposed to be on vacation?
Parent - - By js55 (*****) Date 06-27-2014 19:38
46,'
After two margaritas his memory begins to fail him.  :grin:
Parent - - By 46.00 (****) Date 06-27-2014 19:44
Ahh I have the same problem! But mine lasts 24 hours!
Parent - By ed17 (*) Date 06-27-2014 19:57
me too!! lol!! thanks so much for yourr help!! will post the results when we do the test!!:cool:
