Up Topic Welding Industry / General Welding Discussion / 2012 300D w/Perkins
- - By CoonBait (*) Date 09-11-2014 17:32
Hello all....having issues with this one...while welding gauges bounce irregularly and leads jump as if you were gouging.... Any thoughts
Parent - By yojimbo (***) Date 09-11-2014 19:27
How do the RPMs on the engine sound?  Are they steady or do they fluctuate with the gauges bouncing and arc gouging?  A diesel RPM is set by fuel flow.  If your fuel filter is old/dirty it can starve the machine and tends to "slug" gulps of diesel when it becomes available which can result in higher RPMS and fluctuating current.  Are all the gauges bouncing  or just amp meter?
- - By Regmanager (**) Date 09-11-2014 18:10
Are you leaving your leads curled up on the reels on each side of the machine?
If you are you don't have a problem. It's natural magnetism causing the guages to react
and the coil effect causing the leads to jump.
Parent - By CoonBait (*) Date 09-13-2014 18:17
Now its bogging down almost to the point of dying about half way thru a rod
- By theweldor (*) Date 09-14-2014 00:23
Fuel Filters ?
- - By Dualie (***) Date 09-14-2014 05:08
Id say check your brushes and your brush holders
Parent - - By CoonBait (*) Date 09-14-2014 14:53
Fixing to test it down....its either filters or brushes...if not gonna trash it and go back to Miller
Tear
Parent - - By CoonBait (*) Date 09-14-2014 18:09
Alternator is weak...replacing it to see if that cures
Parent - - By CoonBait (*) Date 09-14-2014 18:20
Is anyone aware of an upgraded alternator for the 440 Perkins
Parent - By ssbn727 (*****) Date 09-16-2014 05:30
Hey Coonbait,
If you want someone with plenty of experience with engine drive welders, then call Kay Sellon of Bill's Welder Repair Service out of OKC, OK and tell her what's going on with your machine... They're one of the best outfits in the country when it comes to repairing engine drive welders of any brand motor installed especially on Lincolns of any model...
Here's their website: http://www.billswelderrepair.com/home.html
Good luck!
