The guide Henry posted is an International version.
OSHA compliance is introducing some new terminology... But the key here to be aware of for compliance is the formatting
In the past, format for MSDS/SDS were not regimented... They will be soon. The format in Henry's post looks like the one OSHA has adopted.
So having your ducks and having your ducks in a row will be the new requirement in 2015
https://www.osha.gov/Publications/HazComm_QuickCard_SafetyData.htmlThe Hazard Communication Standard (HCS) requires chemical manufacturers, distributors, or importers to provide Safety Data Sheets (SDSs) (formerly known as Material Safety Data Sheets or MSDSs) to communicate the hazards of hazardous chemical products. As of June 1, 2015, the HCS will require new SDSs to be in a uniform format, and include the section numbers, the headings, and associated information under the headings below:
