I've got a Cable's Remote with 125' of cable and another 125' in the garage. Not using the spare 125' as much as I thought I would.
I have been wrapping my remote cable around my acetylene hose and frankly getting tired of wrapping it up.
Who has a Cable's remote and what lead reel are you using? I know Mr. Tidwell sells the cable reel but seems his is loaded with wire already and the connection looks different than what is on the Cable's cable. I was looking at the Alumareel 6 wire but pretty sure the Cable's remote is only a four wire.
Looking to make one more good purchase before the end of the year :-)
Give Mitch a call at Alumareel. He'll tell you for certain if his reel will work with a 4-wire remote. Im quite sure it will, but Mitch will have a definitive answer for you. If you buy Alumareel, you won't regret your purchase- top notch products.
