Are your WPSs qualified for notch toughness requirements? It is a trick question, because Section IX doesn't tell the user when notch toughness testing is required. One must know the applicable construction code to determine if and when notch toughness testing must be performed when qualifying the WPS. In short, qualifying the WPS as per Section IX without consulting the applicable construction code (section) isn't sufficient.
