Does anyone have any good pictures of damage from a cylinder going through a wall as the result of a valve being broken off, or damage from a cylinder exploding due to an arc strike? If so, please post them for me! Thanks!
If you can use a video clip, try Youtube. A lot there. Also, the TV show Mythbusters did an episode with compressed gas cylinders going through block walls. Was fairly good.
