Up Topic Welding Industry / General Welding Discussion / aluminum welding
- - By gndchuck (**) Date 10-26-2014 23:54
been a while since I welded aluminum, not too bad on the inside.   Butt joint no gap, TIG DC straight polarity.
Parent - By Tommyjoking (****) Date 10-30-2014 00:08
COOKING  Chuck!!!!
Parent - - By PlasmaHead2 (***) Date 10-30-2014 01:12
What did it look like before you ground it?
Never tried DC on Al my self... the inside looks sweet. I would venture to say full pen has been obtained...
Parent - - By gndchuck (**) Date 11-03-2014 01:06
the outside looked like the inside, just I'm making a stock for my brother, and he didn't want to see the welds :(
DC is just like oxy-weld aluminum, you know aluminum is either solid or liquid and you can't tell when it's about to change.  I'm using DC because I don't have a welder that's capable of AC.
Parent - - By Chris2626 (***) Date 11-05-2014 14:47
did u have to use helium as your shielding gas? i tried dc aluminum once with argon it didn't work i was told i had rouse helium.
Parent - - By gndchuck (**) Date 11-07-2014 01:21
I use argon, have used helium in the past for thick stuff, 3/4" or better, I'm welding 1/8" right now.
Parent - By Chris2626 (***) Date 11-08-2014 03:54
no kidding, guess the aluminum has to be super clean.
