Do you have an MTR for the 1045 & the A732?
Strength Requirements
Ultimate Tensile (ksi) Yield (ksi)
A732 Castings, 1A, 2A, 3A 60, 65, 75 min 40, 45, & 48 min
2Q, 5N 85 min 60 & 55 min
4A, 6N (.4%Mo) 90 min 50 & 60 min
3Q, 13Q 100 & 105 min 90 & 85 min
11Q (1.75% Ni), 4Q 120 & 125 min 85 & 90 min
Is the 1.25" Diameter 1045 round bar cold drawn or hot rolled? Why ask? Because there is a slight difference in tensile and yield strengths with the cold drawn having tensile & yield strengths of 91 & 77 ksi, and the hot rolled having lower tensile & yield strengths of 82 & 45 ksi respectively... In short, you need to look at both MTR's (Material Test Reports) in order to find the exact grade of A732 and 1045 steel that you want to weld together in order to narrow down the strength of filler metal to use because of the wide variations in both members possible T&Y strengths according to each respective grade... Or you can call Lincoln Electric or any of the other major filler metal manufacturers and they should be able to give you a recommendation or two.
