More,
This does not mean that the folks using the SWPS are shady or out of control. A good quality manager could produce work instructions that were fitting for specific scope, material and joints... But do they? How would you verify?
Here is an excerpt from another B2.1 SWPS (AWS B2.1-1-233-200X)
SUPPLEMENTARY INSTRUCTIONS- To adapt this SWPS to a specific application, a user may issue supplementary instructions. Such instructions may consist of tighter fit-up tolerances, higher minimum preheat temperature or any other instructions necessary to produce a weldment that meets the requirements of the fabrication document(s). These instructions shall not be less restrictive than provided in the SWPS.
This one is even more wide open. And when I say open... I mean CJP open roots welded from one side
Standard Welding Procedure Specification (SWPS) for 75% Argon Plus 25% Carbon Dioxide Shielded
Gas Metal Arc Welding (Short Circuiting Transfer Mode) followed by 98% Argon Plus 2% Oxygen Shielded Gas Metal Arc Welding (Spray Transfer Mode)
of Carbon Steel (M-1/P-1/S-1),
Groups 1 and 2,
1/8 through 1-1/2 inch thick,
ER70S-3
That's right... TWO GASSES ! and two transfer modes in one SWPS...
Now the thing is backed by eight, count em, eight PQR's
Put that in your pipe and smoke it !
