"Besides the strength of the filler metal in the joint, the overall strength of the joint or assembly (tube, fitting and joint) following the joining operation must also be considered when choosing whether to use soldered or brazed joints. As discussed, by definition the temperature that defines the difference between soldering and brazing of copper is approximately 840°F/449°C. This temperature is much more important than just an arbitrary definitional threshold. It is important because 700°F/371°C is the temperature at which copper begins to anneal, or be changed from hard temper (rigid) to annealed temper (soft). With this change in temper comes an inherent loss in strength - hard temper copper is stronger than annealed temper copper. The overall amount of annealing that occurs, and thus strength that is lost, is determined by the temperature and the time the material spends at that temperature. The higher the temperature, the less time it takes to change from hard temper to soft temper.
Since brazing temperatures must exceed the melting point of the brazing alloys, between 1,150°F/621°C and 1,550°F/843°C, the process of making a brazed joint causes the base metals to anneal or soften, resulting in a reduction in the overall strength of the assembly. While a brazed joint is demonstrably stronger than a solder joint, the Rated Internal Working Pressure, that is the 24/7 allowable working pressure of the system, is lower for annealed tube (see Copper Tube Handbook, Tables 3a through 3e)." - The link below:
http://www.copper.org/applications/plumbing/cth/technical-data/In this link below there's a chart that shows how E - modulus of elasticity starts @ approximately 17 million psi with the temperature around minus 300 degrees F and then continues to lessen through ) zero degrees F where it's down to 16 million psi and as one continues to follow the line that represents Cu in the chart... The modulus of elasticity - E drops even further to approximately 13.5 million psi @ 700 degrees F which is also where the line ends so any higher in temperature it would probably drop even further and faster...Here's the chart:
http://www.engineeringtoolbox.com/young-modulus-d_773.htmlIf I find something else, I'll post it here.
