![](/mwf/attachments//avatars/4269-2369.jpg)
I've been tasked with grounding a mobile drill rig. I need to come up with a way to easily ground this piece of equipment while onsite inside a substation.
I envision a work clamp (c-clamp style like for a welding table) that can clamp to a copper lug bolted to the chassis of the rig and a 0000 welding cable and then maybe to a copper grounding rod that would be driven into the ground with the hydraulic hammer on the derrick.
But...I wish there was an easy way to remove the grounding rod though when they need to move the drill rig to drill another hole.
Any suggestions?
Anyone here work out of a bucket truck who is familiar with this type of mobile/grounding of a vehicle?
