If you have unlimited resources and a lot of time, go for the gold. If you are working within time and money constrains like most of us, weld the coupon using the welding parameters that provide acceptable test results. Write the WPS using the ranges allowed by the applicable welding standard.
One way of establishing the welding parameters is to run several T-Fillet Break tests and use the parameters that product the best fillet weld results. Read the welding standard carefully, most require the fillet welds, one being the largest single pass fillet, and one the smallest multiple pass fillet weld to be used in production, to be qualified separately from the grooved joint. Once the parameters have been established for the fillet welds, use those parameters to qualify the groove weld.
