Brent wrote:
"remember, when doing the work, the heat will not be concentrated on the tile. It will be on the work piece. You are just trying to absorb or deflect heat from your other items."There is your answer to your question regarding how long you should heat the tole which is what you really want to avoid as much as possible...
Once again, the heat is to be concentrated on the workpiece - NOT the tile - CAPECHE?
I know what I'm about to write isn't something you really want to read but, I will always try to educate, and remind anyone that attempts to perform work that can potentially lead to an accident and injury so here goes anyway... Heck! Why don't you just use Fire brick instead? One cannot be frugal when it comes to making sure you have the proper equipment and materials in order to establish the
safest possible work environment and should always be your first priority! More accidents are caused because of a lack of adhering to making sure the work environment is protected from any and all potential sources to result in causing an accident that can lead to a potential injury...
Safety must always be your first priority or else you may end up seriously injured and will no longer be able to perform anymore work depending on how severe the results are when working in an
unsafe environment... Use the right tool for the job and use the proper
safety equipment as Brent previously mentioned in order to avoid any potential problems so the job can be completed in an effective and
SAFE manner!
SAFETY SHOULD ALWAYS YOUR FIRST PRIORITY instead of saving a few bucks.
