Greetings Mean! "Weldcome" to the World's Greatest Welding Forum of the AWS!!!
Which Miller power source model are you referring to, or just forgot to refer to? With respect to the Lincoln LN-7 wire feeder, go to the Lincoln web site and look up the operation manual for the wire feeder and you should be able to find the schemo for that specific model # wire feeder and you should be able to do the same with the Miller power source with the appropriate model # if you go to the Miller web site as well.
