Up Topic Welding Industry / Technical Discussions / Stainless Etching
- - By MRWeldSoCal (***) Date 01-26-2015 22:52 Edited 01-26-2015 22:58
Hey all of you!
Hope things are going great across the board for you all!  Getting into some metallographic, we do this quite often at my work.  Today however were running into an issue getting a 301 Cres. Stainless to etch.  We have a standard 70% Nitric- 30% Methanol, it is an electrolytic solution and even though the acid corrodes one current is induced, its only wearing down the metal, not staining it.   It will turn its clack nasty color like it is etching but after rinse its gone.  We trying running the hydrochloric and nitric together and got nothing.
Does anyone have a tried and true method for etching chromium and nickel steels?
J MAX
Parent - - By ssbn727 (*****) Date 01-27-2015 00:43
J MAX!
Here's an interesting thread for you to go through...
http://www.finishing.com/151/51.shtml
Look @ this... Go to page 9 of 13 in the .pdf below and look for Kalling's or Marbles Reagent for the chemical composition of these electrolyte solutions:
http://www.metallographic.com/Technical/Basics.pdf
And as a bonus, I'm going to include a 344 page Metallographic Handbook from Pace Technologies:
http://www.metallographic.com/Brochures/Met-Manual-2b.pdf
You should find the answer to your question on page 9 of 13in the first listed .pdf... The book gives you a sort of reference for the subject. enjoy the read!:eek::roll::lol::grin::cool:
Parent - By MRWeldSoCal (***) Date 01-27-2015 18:33
WOW Henry thanks for all that!
Parent - By MRWeldSoCal (***) Date 01-27-2015 19:47
Ok so we ran with a certain set up, I think the problem is that it is a resistance seam weld on near foil thin sheet.  The difference in grain etching is so low heat that its hard to find contrast.  Hmmmm
J MAX
