Up Topic Welding Industry / General Welding Discussion / Why no 5356 when joining 3003
- - By devo (***) Date 01-27-2015 17:53
I ran out of 4043 last night, and after consulting my AlcoTec chart, I was bummed to realize that 5356 isn't recommended for joining 3003.  Why not and what will happen to the weld?
Parent - - By Lawrence (*****) Date 01-27-2015 20:26
Typically when 3003 aluminum is welded to itself 1100 (at least according to D1.2)  I've done plenty of non code work with 4043.
3003 is minimally alloyed and I suspect that the 5000 series fillers have an "over alloying" negative effect of some sort.
According to D1.2
3003 is an M21 grouping base metal
1100 is an F21 grouping filler metal
5356 is an F22 grouping base metal
4043 is an F23 grouping base metal
At least according to D2 the F groups are an essential variable ( I assume with good reason)
Here is the most complicated filler metal chart I've seen in my life :)
http://www.hobartbrothers.com/downloads/aluminum_filler__eNttQ.pdf
It allows for several fillers for 3003 base metal.. But no 5356
Sorry to be so unhelpful...  I think it may be a "fit for purpose" issue if your doing non-code work..  But I would not move forward (without a competent engineering variance) with an filler that neither the manufacturers or code accepts if it is for anything other than home shelving or decorative work :)
Parent - By devo (***) Date 01-27-2015 22:47
Thanks Lawrence.  This is for a sheet metal post cap, so totally non code.  I used to dislike 4043, but after over 300 feet of weld on these post caps, I'm getting used to it.
