Up Topic American Welding Society Services / Certifications / Changing weld wire
- - By Weldenthu Date 01-29-2015 21:47
Guys,
I am planning to switch weld wire on structural weldment. I want to go from Lincoln L-56 0.045 wire to 0.035 wire. I was wondering what kind of qualification test I should be doing ? Are there any AWS standards?
I am reducing wire size so its easy to achieve weld callouts and we are not over welding.
Parent - - By Lawrence (*****) Date 01-29-2015 22:01
There are literally dozens of AWS standards.  Each unique in their requirements.
To which standard must your production work comply?
Only with that information can you get an answer that means anything.
Hint:  If AWS D1.1
For Welding Performance Qualifications see Table 4.12
For Welding Procedure Qualifications see Table 4.5  (10)
Parent - - By Weldenthu Date 01-29-2015 23:55
Lawrence,
Thanks for your reply. We dont follow any AWS standards. We make self propelled sprayer.
Would this information help you in deciding what AWS standards we need?
Parent - - By welderbrent (*****) Date 01-30-2015 00:31
If your components are less than or equal to 3/16" then D1.3 could apply.  If there are some that are over 3/16" then D1.1 could apply (it actually applies to materials 1/8" and over so there is an overlapping area).
Now, if you didn't catch Lawrence's drift, there is a difference between Welder Performance Qualification (that's for qualifying the person) and Welding Procedure Qualification (that's for the actual procedure to be followed by the qualified welder).  The procedure qual and resulting wps tells the welders what process to use, what gas, gas pressure, electrode classification, and much more.  They will use that to qualify to as well as work to though you can have separate ones for the two operations.  The different tables he mentioned will guide you as to what you can and can't do.
There is also a difference between a standard and a code.  D1.1 and D1.3 are codes.
Now, before I stray too far, being the kind of equipment you mentioned it is quite possible that one of the D14.X codes applies instead.  They follow D1.1 pretty close but not exactly.
So, having just scratched the surface, this is why more information is usually needed to give complete and accurate answers.
Parent - - By fschweighardt (***) Date 01-30-2015 02:55
All codes are standards, but not all standards are codes
Parent - By ssbn727 (*****) Date 01-31-2015 04:24
Especially if it has the abbreviation: "ANSI.":eek::roll::lol::yell::twisted::lol::grin::wink::cool: Those letters are the abbreviation for: American National Standards Institute.:grin::cool:
Parent - By aevald (*****) Date 01-30-2015 04:02
Hello Weldenthu, if I have this right, you folks are an OEM and you don't have to comply with any specific welding codes or standards. If that is the case, I believe that you will not have any issues with the change in wire diameter.
If your welding call-outs are based on general welding engineering practices you will only need to concern yourself with meeting weld size conditions. In addition, considering whether the finished welds are without excessive or undue undercut or overlap/cold lap. I've based the aforementioned comment on using weld parameters where you might be a bit out of range for the welding based upon how you apply the smaller diameter wire, ie. possibly you plan on running a single pass 1/2" fillet or something of that nature and so you are running extra voltage and wire speed to hopefully make this happen. I realize that this example is out there and may not represent any of the conditions of your actual manufacturing practices nor have any application to your specific question. I'll be interested to hear more though, so please include a bit more information if you can. Good luck and Best regards, Allan
- By 803056 (*****) Date 01-30-2015 14:29
Go to the AWS Bookstore and search for the D14.X standards. There are several; D14.1, D14.2, etc. You can use the one intended for construction equipment as a guide.
The D14 standards are welding standards that includes base metals commonly used for the manufacture of "equipment" and they are "industry best practice." That is a major point if your employer is entangled in litigation. It can mean the difference in the amount awarded to a plaintiff in the event of a judgment against your employer. If the defendant (your employer) can show they followed industry best practices, the chances of the plaintiff claiming negligence is mitigated and the amount awarded is reduced.
