Up Topic American Welding Society Services / Technical Standards & Publications / Question about dissimilar thickness, problem in root
- - By meisam Date 02-09-2015 12:32
Dear Experts
In the attached images which are macrographs of a sample that welded 8" pipe to 8" pipe (about 12mm thick to 16mm thick). The offset done by the surface allignment so the effect of dissimilar thickness is in root of the weld.
The questions are, according to AWS D1.1 (consider it as a statically loaded):
1 - Is this joint design is permitted or not?
2 - What is your idea about the surface which is marked with "A" letter? It could be LOF or any other type of flaw?
Parent - By welderbrent (*****) Date 02-09-2015 14:13
Answers already started in same post started in another section.
BB
Parent - By Jmaziyar (*) Date 02-25-2015 07:41
Hi meisam
You can refer to item 2.25 & Fig. 2.21 on transition of thickness of but joint in unequal thickness.
