Up Topic Welding Industry / General Welding Discussion / inconel 625
- - By weaver (***) Date 03-02-2015 12:25
Good Morning,
Once upon a time I saw a weld caculator to determine costs of wire and gas usage. We are using hotwire Tig with .035 625 inconel @ 143IPM and 40cfh of 100% argon. I am trying to dial in exactly how much were spending per hour in consumables. Also how many inches or feet of wire is on a 33lb spool? Thankyou in advance, Shannon
Parent - - By Lawrence (*****) Date 03-02-2015 15:20
http://www.brookfieldwire.com/gauge_chart.pdf
This should bring you pretty close.
Parent - - By weaver (***) Date 03-02-2015 15:48
Thankyou Lawerence, am I reading this right that there's 304 ft per spool? That figure seems low.
kind regards,  Shannon
Parent - - By Lawrence (*****) Date 03-02-2015 16:28 Edited 03-02-2015 16:59
304 feet per pound  :)
10032 feet per 33 pound spool
304 x 12 = 3648 inches per pound.
143 inches per minute x 60 = 8580 inches (715 feet) of filler per hour.
715 feet divided by 304 feet per pound = 2.35 lbs. per hour deposition rate. Assuming a 100% operating factor and 100% electrode efficiency
Parent - - By Milton Gravitt (***) Date 03-02-2015 16:54
If you go to the bottom of that page it tells you to divide by 1.067 to get the anwser.
                 M.G.
Parent - - By Lawrence (*****) Date 03-02-2015 17:03
Ok so make the above assumptions based on 284 feet rather than 304 :)
Parent - By fschweighardt (***) Date 03-02-2015 19:16
gas is easy, scfh as read by flowmeter x cost per unit of measure usually per 100 SCF
