Up Topic Welding Industry / Technical Discussions / Sheilding Gas Guidlines
- - By Jarhead1 (**) Date 03-02-2015 22:12
Are there any "general” guidelines  for sheilding gas flow-rates (CFH) for GMAW/GTAW for different materials and thicknesses. As a rule of thumb, I was taught long ago 15-30 CFH for TIG/MIG.
Its really difficult to find any AWS documentation referencing for gas flow.
Any charts/formulas available that I can use for inside welding only....
Best Regards.
Parent - By Lawrence (*****) Date 03-03-2015 12:54
GMAW with a 5/8" nozzle typically runs between 30-45 CFH for manual operations... Maybe slightly higher for high speed automation.
GTAW cup/nozzles are sized with a number..  The number represents 1/16" inside diameter.  Typical might be 15 CFH for a #4 up to about 25-30 for a #10
External factors such as air movement, travel speed, gun angle, diffuser type will have an effect.
Any welding textbook produced in the last 25 years has this information.
Here is a quick online reference for GTAW
http://www.ckworldwide.com/technical_specs.pdf
Good GMAW basics here
http://www.thefabricator.com/article/arcwelding/preparing-for-gmaw-back-to-basics-all-about-setup
Parent - By jwright650 (*****) Date 03-03-2015 12:59
Also....check the data sheets produced by your welding electrode mfg....a lot of times they have suggested cfh values for using their product listed on these documents.
Parent - - By trapdoor (**) Date 03-03-2015 18:24
Parent - By trapdoor (**) Date 03-09-2015 16:01
Wow I didn't notice that one. Just goes to show you learn something every day.
Parent - By Metarinka (****) Date 03-09-2015 18:31
as a general rule we start around 20cfh for TIG then adjust down until it gives us issues (on a test piece) then backoff. True number is usually around 15 CFH, any lower and the savings from the gas is eaten up by possible defects.   Same thing for GMAW.
Parent - By t_rod7018 (*) Date 03-12-2015 18:11
Hi Jarhead,
Not sure if you're just using aluminum, but this handbook has been very helpful.
http://pubs.aws.org/p/271/phb-8-the-everyday-pocket-handbook-for-gas-metal-arc-welding-gmaw-of-aluminum
Tori
