Hello Tommy, thanks for including that bit of information. As you said, there are a number of things that seem rather simple when you have been out there for a while, yet you don't necessarily see them spelled out anywhere. Just have to spend some time with the more experienced ones to pick up on these sorts of things. Thanks for sharing and best regards, Allan
Hi Tommy, me again. I have a few photos that might add a bit of "visuality"(is that a word? Oh Well) to your descriptions. Best regards, Allan
Good point Tommy, and illustrations Allan, and it also goes along with your dog and wedge illustrations.
Let me give another practical example:
When in the Boilermakers on petroleum storage tank construction, each 'ring' would be slightly thinner in gauge. Many would start at ground level between 3/4 - 1" and get thinner. By the time we got to the top we were between 1/4 -3/8". All depends upon the height, diameter, and other engineering considerations.
We started on the plate floor with tabs as in Allan's illustrations and formed the ring to fit. You then place tabs on the top of the first ring and fit the next ring to those and as you did the final fit you used your dog to move the second plate over a tiny bit to compensate for the thickness change in the plates. Along with key plates, nuts, and bull pins to line up and fit the vertical seams you went around and fit the ring.
When all fitting and welding was complete, the diameter came out right, the offset in rings was right, there were no 'peaks' in the verticals, etc. If, everyone knew their job and did it right.
The tabs doubled as a first fit, final fit aid that was very handy.
Hey Tommy,
Hope things are going good for ya
I've ended up doing things of this nature so often that I have a bin of small bits of various thickness random material...
Cold rolled bar stock is one of the most collected. And bits of angles...
Aluminum stainless and steel... nice square edges and nice nominal numbers.
If .248" isn't close enough to 1/4" then it doesn't belong on my table, go talk to the machinists next door...
-Clif
By Tommyjoking
Date 04-01-2015 02:29
Edited 04-01-2015 02:34
Oh heck Clif,,,,,,,,I keep little pieces in my bucket if im a welder on the job just for this and that........as you go along you will see what will help you and what won't. These days I always keep a cutoff wheel and chucks handy for a four inch......I also keep a couple of thin pipe spacers handy for leveling stuff. FARGIN structural work there is ALWAYS a gap to fill with weld meat.
you will be surprised out on the road how often a sliver of bar stock or rolled stock will make you day.
