What exactly is the corrosive environment, is it a pickling acid or something more aggresive ?
The reason i am asking is, we have an application using Alloy 20 welded to alloy 20 and we use 320 welding wire , which is the matching filler reccomended by the manufacturer. If you provide me with the details, i could look into this in more depth. Things are kind of slow for me right now so it would be no problem.
I can be reached at Cstewart@noram-eng.com or you can call direct at (604)681-2030 ext 255
Colin :)
