Up Topic Welding Industry / Technical Discussions / Welder Qualfication on SS400.
- - By nhuanbk Date 04-10-2015 04:17
Dear Pro,
I have available pre-qualified WPS (AWS D1.1) for ASTM A36.
But now A36 raw material not yet available.
Can i use JIS G3101 SS400 material for Welder qualification, base metal qualified range will be?
Parent - By 803056 (*****) Date 04-10-2015 15:31
I would direct the question to the Engineer for resolution.
Welder qualification a a demonstration the welder can deposit sound weld. Once qualified, the welder is qualified to weld a range of base metals. In some cases, a code will allow the welder to weld base metals from several families based on a single welder qualification test. For example, ASME allows the welder, qualified on carbon steel, to weld both carbon steels, austenitic stainless steels, and nickel alloys in production.
I am not familiar with JIS G3101 SS400, so I can not say whether it is similar to ASTM A36 based on chemistry or mechanical properties. Nor can I predict whether the Engineer (representing the owner) would permit the substitution.
Parent - By Joey (***) Date 04-23-2015 04:24
SS400 is weldable material. It's a privelage that you can identify the material.
Here, we get materials from scrap yard for welder qualification test :razz:
