Let's not confuse AWS with ASME.
Let's not forget that ASME is one code that doesn't require the welding parameters listed on the WPS to be based on the parameters used to qualify the WPS using a plate or pipe test. The parameters listed by the WPS can be pure fiction and per ASME Section IX they are perfectly acceptable for production welding.
While the parameters used to weld the test plate (or pipe) coupon worked for that particular application, they are considered to be nonessential variables. Thus, there is no requirement that the parameters be recorded on the PQR. The parameters are lost to the ether if they are not recorded, thus the parameters listed by the WPS are likely pulled from the butt of the individual tasked with writing the WPS.
The rest of the real world limits the range of the welding parameters listed by the WPS to be based on the parameters recorded on the PQR, i.e., Voltage +/- X%, amperage +/- Y%, and so on. Thus, if the parameters used to qualify the plate test are inappropriate for the fillet welds needed for production, the soundness test, i.e., the macroetches, allows the contractor to determine what parameters are needed to make the required weld size. The parameters used to deposit the required weld sizes (qualifying the fillet procedures) are then used as the basis of the welding parameters used for production fillets. The WPS lists welding parameters that are based on actual test results rather than conjecture.
Different codes, different committees, different interests, different relevant work experience produce different code requirements.
