AWS D1.1 has provisions for tubular connections whether they are tubular members to plate or tubular member to another tubular member. The design provisions are addressed in Clause 2. The qualification requirements for WPSs that are not prequalified addressed in Clause 4.
The conditions of prequalification are addressed in Clause 3. if you cannot meet all the conditions of prequalification, the WPS must be qualified per the requirements of Clause 4.
You are correct in your assessment that AWS D1.1 does not address systems that are pressurized and covered by another code such as ASME pressure piping codes.
Ganglywrench,
WELCOME TO THE AWS WELDING FORUM!! And it's new format as well.
The D10 materials that you reference in your title line are reference works only, as opposed to the codes and standards of other sections.
D1.1 Structural Steel appears to be the best place for your work to be classified. Their impact would be structural even though they are not a supporting part of a building. They sure don't fit under Automotive, Bridge, Machinery, etc. And they would not fit into classifications per ASME, API, or other pipe related codes either.
So, as such, we must deal with what we have. The product then being fabricated and inspected under the D1.1 code your welders would be fully qualified to weld it if they are currently qualified to weld to D1.1. There may be additional testing to do if you have pipe fittings that need qualification not covered by a plate test. And, as Al stated, you may need PQR testing per Clause 4 if you can not come up with a joint, process, and total fabrication that is pre-qualified per Clause 3.
To fully answer and/or give any further guidance we really need some additional info:
Type/grade of pipe; joint, welding process, overall product configuration (we may be able to offer suggestions for new design that would make the joints pre-qualified), etc.
A picture would be great but not always possible. Drawings work also.
