Solcat,
Typical. Everyone tries to find an excuse for asking for more money. Bid low, find any possible reason to issue a change order to ask for more money so you might actually break even.
Now, you haven't told us what code applies, what materials are in use, what welding process is being used, and if all other requirements (WPS's, WPQR's, MTR's, etc) are taken care of.
But, first, the client is already paying for the NDT, not you or the sub. No cause there for more money.
Second, there was already time calculated for hold points to accomplish MT or PT and it really won't hold the sub up any more to do UT.
Thus, the only reason for more time is because he knows he has sloppy welders and there will be repairs that UT can pick up that MT never could. His problem, not your's nor the client's.
And, UT won't really be accomplishing anything on the PJP's anyway other than a rough estimate on depth of penetration and only then with the right technician and care while performing.
Remember, once an indication that is determined to be rejectable is found, repaired, and called for re-inspect, the re-inspect is on the fabricator. His time to repair the spot and the new inspection is on him, not the client.
Personally, tell him to go fish.
My two tin pennies worth.
