Dear All,
My question is about the API 5L electrical characteristics ( I,V , v and HI ) tolerances requirements for the SAW-H PSL-2 linepipe manifacturing .
In accordance with Appendix B of API 5L , there is no guidence for the Heat Input , current , voltage and arc speed tolerances can be put in a line pipe manifacturing WPS.
Can ASME IX requirements ( supplementary essentials ) be used as a guidence?
In addition , ASME IX does not limit the minimum heat input however, in our project we have hardness limitation ( max to be 275 HV10 )
If ASME IX can be used as a guidence for heat inputs what will be the justification for the hardness ? as lowering heat input may increase the hardness
Any advise will be much appreciated.
TA welding.
