Dear All,
I would need a big favor. I have come across with a new work in the job of rail welding. I am not very much skilled in this procedure. Could I please ask you to share the procedure if you have one with you? If not, please tell me what code or references clause I should follow. And also if I have completed work with the procedure and a repair is found please refer me the references that tell me the Repair procedures. Thank you, my dear friend, for your valuable help in this regard.
Note : If any one Please send me the Rail welding procedure (PQR + WPS) and repair welding procedure if you have. I need that to refer some requirements.
Welding procedure: Thermit welding
Magesh
