Up Topic Welding Industry / ASME Codes / Buildup on Parent material
- - By QAQC Weld Date 06-22-2015 06:25
Hi all,
Can anyone advise if it is advisable to buildup parent material with OD of 1100mm to 1165mm and machined down to 1160mm used for high pressure flange?
Regards,
QAQC weld
Parent - - By aevald (*****) Date 06-22-2015 06:40
Hello QAQC Weld, without knowing the material type and specifications it will probably be difficult to receive an answer. Without specifics I would believe that your question should be posed to the engineer of record and the responsible individual can provide a yes or no answer. Best regards, Allan
Parent - By QAQC Weld Date 06-23-2015 08:20
Base material is aisi 4130 75ksi and the code is ASME Sect. IX. Additionally the process is SAW.
Parent - - By jon20013 (*****) Date 06-22-2015 10:26
What is the Code you're constructing to QAQC Weld and what is the base material specification?
Parent - - By QAQC Weld Date 06-23-2015 08:04 Edited 06-23-2015 08:07
hi jon 20013,
Parent - - By jon20013 (*****) Date 06-24-2015 03:27 Edited 06-24-2015 05:30
QAQC Weld, not asking ASME IX but rather what code are you building / constructing to?  You mention building up a high pressure flange so is it pressure vessels / tanks or piping that you're dealing with?  There will be a governing construction code if these are the cases....
Parent - - By QAQC Weld Date 07-06-2015 02:44
hey jon20013, i m building a spacer spool to be exact under API 6A 20th edition.
Parent - By jon20013 (*****) Date 07-07-2015 05:13
Cool QAQCWeld, API 6A is where you'd find your answer about acceptance of weld metal used as a base metal build-up then.  Seriously not meaning to sound like a smart ass but that's where the answer would be... ASME IX would be mute on that topic.
