I stole it.
Found it with a Google search of corner welds couldn't get some of mine to work taking them from my codes and specs on the computer.
See above but it is simply a fillet weld as drawn.
See drawing attached here thanks to Al. This is a fillet weld. It is also a fillet weld when used in a 90° application as previously stated on lap and corner joints as well as T joints.
It is important to always keep 'joints' and 'welds' separated in our mind and terminology. There is no such thing as a fillet joint. There is no such thing as a corner weld, lap weld, T weld, etc.
A good reference is A3.0 Defs and Terms, and A2.4 Weld Symbols. So also the section on Weld Symbols in the WIT book (Welding Inspection Technology) available from AWS.
Brent
