In your case I would say it is more the shielding gas percentages that determine transfer mode not volts and amps. Not real familiar with the conditions on Stainless but I don't believe you are working with Spray Transfer. So that limits the options as to what you ARE working to.
The second part then becomes one of what the electrode manufacturer's suggested and tested specifications are. They are normally listed on various available fact sheets from all the biggies. Just go to their website and look it up if you don't have anything on it and it will tell you volts, amps, size of electrodes as tested, gas mixes, etc. This is part of making sure a process in Pre-Approved/Qualified, that it is within Manufacturer's tested procedures.
If you were running on carbon steel you would be within normally accepted volts and WFS for Spray, but not gas and I don't know for sure with Stainless.
