90/10 is pretty easy to braze. Using fittings with consumable rings is a good idea. You just have to remeber that cleanliness is next to Godliness, use plenty of clean flux, and the filler will draw toward the heat.
That thickness will take plenty of heat, but don't over do it. Try to heat it evenly so that both fitting and pipe reach the melting temp of the filler at the same time. Use a neutral to carbeurizing flame to heat the surrounding areas outside of the joint, don't direct the flame tip into the joint.
Once you see the filler flow on the pipe all around the joint, back off. If you overheat it, the flux will cook out and you'll wind up with leaks. Red hot is way too hot.
The heat discoloration and cooked flux will make the final joint look like crap. If you need it clean, wire brush it afterward.
Tim
