Here is a thread on the Jackson Balder hood posted about a year and a half ago.
https://app.aws.org/forum/topic_show.pl?pid=256506;hl=welding%20hoodsThe old grouch Paladin posted a bit of a review and thoughts on the Jackson and hoods in general in that thread.
I have both the Jackson Balder and the Miller Digital Elite out for everyday use. I most always use the Balder for welding regardless of process. I use the Miller for torch cutting because it has a torch mode. The Jackson does not.
The Jackson Balder has a fairly comfortable head gear but read the review for more info. But like most hoods I have ever used, unless one has it screwed down tight on your head, bending over ( head down) will send it off your head. I'm pretty good at catching it as it comes off. Practice.
I'm on my third Miller Digital Elite. The new style head gear is a FAIL in my opinion. It seemed like it would be good. But I soon changed it out for an the previous design head gear from an older Miller I had. If I remember, it (new miller head gear) was even worse for flying off my head and friction to control the head shake drop was not consistent. But the biggest fault (to me) is when you fully raise the hood it stops at an angle that when leaning over the full weight of the hood pulls it down or off your head. If that stop was not there or would let the hood tilt further back, one could lean over a little with out the hood falling down, and you could still cause it to drop with a modest head shake.
The very old Jacksons had no stops on them. This was long,long, ago before auto lens hoods. If you were not about to weld you could tilt it back far enough and it would stay up. Then when your were about to tack or weld, bring it forward to the tipping point, hold piece of steel in one hand, stinger in the other, gentle nod of the head and in the business of welding.
Floyd
