What do you all suggest to use to clean parts & filler rods (alum. & stainless steel) prior to welding? We have been using MEK as that's one of the cleaners that is approved by all of our customers. The other is isopropyl alcohol. Both I understand are flammable & the fumes aren't too nice either. We started using MEK because we had it already and alot of our other bonding processes require MEK. The higher ups want me to find something safe, non-toxic, non-flammable, and something that is approved for use by all of our customers... is there such a thing?! If no such thing exists & I have to keep using MEK or alcohol, what are your suggestions for use? The higher ups think we need a special cleaning booth that is ventilated, and it must be far away from the weld shop.. because at any moment the sparks from the welding could blow the place up! (we Tig weld, sparks are few & far between, if any at all). Currently, they are making the welder walk about 200ft round trip to wipe a part off in a "safe" area... they are killing production time by doing this. It's not like the welder had the MEK next to his torch. He was technically outside of his work space at a work bench where we stage the parts for welding. Plus there is an overhead fan above the bench.
I'm new to welding & got this whole mess dumped on me a few months ago. I'm literally learning on the run. So any help will be greatly appreciated. Thanks
