Hi
This material you are welding is very thin. I have never been involved in welding copper this thin. Are you sure it is not maybe 0.055"?
At any rate, with such a thin material you would not typically need any gap or weld prep. Also, no pre-heat would generally be required. In general you should have little problem welding oxygen free copper, unless it has been exposed to elevated temperatures for some time, because then it could have absorbed some oxygen.
Annealing would rarely be required, but you can anneal at 700 - 1200°F for 15 - 30 minutes. At the higher temperatures, grain growth will become a problem.
Hope this helps
Niekie Jooste
