The minimum specified tensile strength of the filler metal is 80 ksi. The minimum tensile strength of the base metal is 85 ksi. Did you consider the A number of the filler metal? If the change from 80 to 90 ksi filler metal affects a change in the A number, that would be considered an essential variable.
