Up Topic Welding Industry / General Welding Discussion / API 582 vs ASME Section IX
- - By AdhiBTI Date 09-10-2015 10:50
Hello,
Can anyone Tell what are the major difference in welding Requirements between API 582 and ASME section IX.
Parent - - By In Tension (**) Date 09-10-2015 23:53
For procedure qualification not much changes:
4.1 Structural (nonpressure boundary) welding requirements shall comply with either AWS D1.1 or AWS D1.6.
When approved by the purchaser (engineer) welding procedures may be qualified per ASME BPVC Section IX.
For fabrication purposes there are additional requirements that are not addressed by Section IX because Section IX isn't a building code.  What welding processes are you using and what do you intend to use it for?
Parent - By AdhiBTI Date 09-11-2015 06:21
Thanks for your quick update . We generally use FCAW welding process.
